2019-05-13 14:28:28 INFO [kz.gov.pki.osgi.layer.core.NCALayer] - NCALayer 1.2
2019-05-13 14:28:28 DEBUG [uk.org.lidalia.sysoutslf4j.context.SysOutOverSLF4JInitialiser] - Your logging framework class ch.qos.logback.classic.Logger should not need access to the standard println methods on the console, so you should not need to register a logging system package.
2019-05-13 14:28:28 INFO [uk.org.lidalia.sysoutslf4j.context.SysOutOverSLF4J] - Replaced standard System.out and System.err PrintStreams with SLF4JPrintStreams
2019-05-13 14:28:28 INFO [uk.org.lidalia.sysoutslf4j.context.SysOutOverSLF4J] - Redirected System.out and System.err to SLF4J for this context
2019-05-13 14:28:28 INFO [kz.gov.pki.osgi.layer.core.NCALayer] - Linux
2019-05-13 14:28:28 INFO [kz.gov.pki.osgi.layer.core.NCALayer] - 4.18.0-18-generic
2019-05-13 14:28:28 INFO [kz.gov.pki.osgi.layer.core.NCALayer] - /usr/lib/jvm/java-8-openjdk-amd64/jre
2019-05-13 14:28:28 INFO [kz.gov.pki.osgi.layer.core.NCALayer] - 1.8.0_191
2019-05-13 14:28:28 INFO [kz.gov.pki.osgi.layer.core.NCALayer] - /home/nickidev/.config/NCALayer
2019-05-13 14:28:28 INFO [kz.gov.pki.osgi.layer.core.NCALayer] - /home/nickidev/nca/ncalayer.sh
2019-05-13 14:28:29 INFO [kz.gov.pki.osgi.layer.core.VerifierKt] - Certificate: [278463781514179169959691607844149928005467174640] [EMAILADDRESS=AIRAT.KHAIRULIN@NITEC.KZ, GIVENNAME=МИНВАЛИЕВИЧ, OU=BIN000740000728, O="АКЦИОНЕРНОЕ ОБЩЕСТВО \"НАЦИОНАЛЬНЫЕ ИНФОРМАЦИОННЫЕ ТЕХНОЛОГИИ\"", ST=АСТАНА, L=АСТАНА, C=KZ, SERIALNUMBER=IIN761231300313, SURNAME=ХАЙРУЛИН, CN=ХАЙРУЛИН АЙРАТ] [Mon Jan 24 20:20:49 ALMT 2022]
2019-05-13 14:28:29 INFO [kz.gov.pki.osgi.layer.core.NCALayer] - System packages: javafx.beans.property,javafx.beans.value,javafx.scene.control.cell,javafx.scene.image,javafx.event,javafx.util,kz.gov.pki.osgi.layer.api,org.json,kotlin,kotlin.jvm.internal,kotlin.collections,org.osgi.service.log,org.slf4j,org.slf4j.impl,javax.smartcardio,javafx.application,javafx.collections,javafx.fxml,javafx.geometry,javafx.scene,javafx.scene.control,javafx.scene.layout,javafx.scene.paint,javafx.scene.text,javafx.scene.web,javafx.stage,javafx.util,javax.xml.parsers,org.w3c.dom,org.xml.sax,javax.net.ssl,javax.swing,javax.xml.namespace,javax.xml.stream,javax.xml.stream.events,javax.crypto,sun.security.jca,javax.crypto.spec,javax.servlet,sun.security.smartcardio
2019-05-13 14:28:29 INFO [kz.gov.pki.osgi.layer.core.NCALayer] - Scanning bundles directory...
2019-05-13 14:28:29 INFO [kz.gov.pki.osgi.layer.core.NCALayer] - (org.apache.felix.framework 5.6.10) is 8
2019-05-13 14:28:29 INFO [kz.gov.pki.osgi.layer.core.CertCondition] - Condition for kz.gov.pki.knca.applet.knca_applet is true
2019-05-13 14:28:30 INFO [kz.gov.pki.osgi.layer.core.CertCondition] - Condition for kz.gov.pki.kalkan.xmldsig is true
2019-05-13 14:28:30 INFO [kz.gov.pki.osgi.layer.core.CertCondition] - Condition for kz.gov.pki.kalkan.knca_provider_jce_kalkan is true
2019-05-13 14:28:30 INFO [kz.gov.pki.osgi.layer.core.CertCondition] - Condition for kz.gov.pki.provider.knca_provider_util is true
2019-05-13 14:28:31 INFO [kz.gov.pki.osgi.layer.core.CertCondition] - Condition for kz.gov.pki.osgi.layer.websocket is true
2019-05-13 14:28:31 INFO [kz.gov.pki.osgi.layer.core.CertCondition] - Condition for kz.gov.pki.api.layer.NCALayerServices is true
2019-05-13 14:28:31 INFO [kz.gov.pki.api.layer.service.LogWriter] - [kz.gov.pki.api.layer.NCALayerServices]: BundleEvent RESOLVED
2019-05-13 14:28:31 INFO [kz.gov.pki.api.layer.service.LogWriter] - [kz.gov.pki.provider.knca_provider_util]: BundleEvent STARTED
2019-05-13 14:28:31 INFO [kz.gov.pki.api.layer.service.LogWriter] - [kz.gov.pki.kalkan.xmldsig]: BundleEvent STARTED
2019-05-13 14:28:31 INFO [kz.gov.pki.api.layer.service.LogWriter] - [kz.gov.pki.osgi.layer.websocket]: BundleEvent STARTED
2019-05-13 14:28:31 INFO [kz.gov.pki.api.layer.service.LogWriter] - [kz.gov.pki.osgi.layer.websocket]: Found LogService on load
2019-05-13 14:28:31 INFO [kz.gov.pki.api.layer.service.LogWriter] - [kz.gov.pki.osgi.layer.websocket]: BundleEvent RESOLVED
2019-05-13 14:28:31 INFO [kz.gov.pki.api.layer.service.LogWriter] - [kz.gov.pki.knca.applet.knca_applet]: BundleEvent STARTED
2019-05-13 14:28:31 INFO [kz.gov.pki.api.layer.service.LogWriter] - [kz.gov.pki.knca.applet.knca_applet]: ServiceEvent REGISTERED
2019-05-13 14:28:31 INFO [kz.gov.pki.api.layer.service.LogWriter] - [kz.gov.pki.knca.applet.knca_applet]: Found LogService on load
2019-05-13 14:28:31 INFO [kz.gov.pki.api.layer.service.LogWriter] - [kz.gov.pki.knca.applet.knca_applet]: BundleEvent RESOLVED
2019-05-13 14:28:31 INFO [kz.gov.pki.api.layer.service.LogWriter] - [kz.gov.pki.kalkan.xmldsig]: BundleEvent RESOLVED
2019-05-13 14:28:31 INFO [kz.gov.pki.api.layer.service.LogWriter] - [kz.gov.pki.provider.knca_provider_util]: BundleEvent RESOLVED
2019-05-13 14:28:31 INFO [kz.gov.pki.api.layer.service.LogWriter] - [kz.gov.pki.kalkan.knca_provider_jce_kalkan]: BundleEvent RESOLVED
2019-05-13 14:28:31 INFO [kz.gov.pki.api.layer.service.LogWriter] - [org.apache.felix.framework]: ServiceEvent REGISTERED
2019-05-13 14:28:31 INFO [kz.gov.pki.api.layer.service.LogWriter] - [kz.gov.pki.api.layer.NCALayerServices]: Found LogService on load
2019-05-13 14:28:31 ERROR [kz.gov.pki.osgi.layer.core.FelixLogger] - [kz.gov.pki.api.layer.NCALayerServices]: Error starting file:/home/nickidev/.config/NCALayer/bundles/NCALayerServices-0.4.jar:
org.osgi.framework.BundleException: Activator start error in bundle kz.gov.pki.api.layer.NCALayerServices [5].
at org.apache.felix.framework.Felix.activateBundle(Felix.java:2290)
at org.apache.felix.framework.Felix.startBundle(Felix.java:2146)
at org.apache.felix.framework.Felix.setActiveStartLevel(Felix.java:1373)
at org.apache.felix.framework.FrameworkStartLevelImpl.run(FrameworkStartLevelImpl.java:308)
at java.lang.Thread.run(Thread.java:748)
Caused by: java.lang.NoClassDefFoundError: javafx/application/Platform
at kz.gov.pki.api.layer.fx.NCALayerServiceImpl.<init>(NCALayerServiceImpl.java:39)
at kz.gov.pki.api.layer.fx.NCALayerServicesActivator.start(NCALayerServicesActivator.java:50)
at org.apache.felix.framework.util.SecureAction$Actions.run(SecureAction.java:1709)
at java.security.AccessController.doPrivileged(Native Method)
at org.apache.felix.framework.util.SecureAction.startActivator(SecureAction.java:688)
at org.apache.felix.framework.Felix.activateBundle(Felix.java:2240)
... 4 common frames omitted
Caused by: java.lang.ClassNotFoundException: javafx.application.Platform
at java.net.URLClassLoader.findClass(URLClassLoader.java:382)
at java.lang.ClassLoader.loadClass(ClassLoader.java:424)
at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:349)
at java.lang.ClassLoader.loadClass(ClassLoader.java:357)
at org.apache.felix.framework.ExtensionManager$ExtensionManagerWiring.getClassByDelegation(ExtensionManager.java:940)
at org.apache.felix.framework.BundleWiringImpl.searchImports(BundleWiringImpl.java:1660)
at org.apache.felix.framework.BundleWiringImpl.findClassOrResourceByDelegation(BundleWiringImpl.java:1590)
at org.apache.felix.framework.BundleWiringImpl.access$200(BundleWiringImpl.java:80)
at org.apache.felix.framework.BundleWiringImpl$BundleClassLoader.loadClass(BundleWiringImpl.java:2053)
... 10 common frames omitted
2019-05-13 14:28:31 INFO [kz.gov.pki.osgi.layer.core.NCALayer] - (kz.gov.pki.knca.applet.knca_applet 0.3.7) is 32
2019-05-13 14:28:31 INFO [kz.gov.pki.osgi.layer.core.NCALayer] - (kz.gov.pki.osgi.layer.websocket 0.3.2) is 32
2019-05-13 14:28:31 INFO [kz.gov.pki.osgi.layer.core.NCALayer] - (kz.gov.pki.kalkan.xmldsig 0.3.0) is 32
2019-05-13 14:28:31 INFO [kz.gov.pki.osgi.layer.core.NCALayer] - (kz.gov.pki.provider.knca_provider_util 0.7.3) is 32
2019-05-13 14:28:31 INFO [kz.gov.pki.osgi.layer.core.NCALayer] - (kz.gov.pki.api.layer.NCALayerServices 0.4.0) is 4
2019-05-13 14:28:31 INFO [kz.gov.pki.api.layer.service.LogWriter] - [org.apache.felix.framework]: FrameworkEvent STARTED
2019-05-13 14:28:31 INFO [kz.gov.pki.api.layer.service.LogWriter] - [org.apache.felix.framework]: BundleEvent STARTED
2019-05-13 14:28:31 ERROR [kz.gov.pki.api.layer.service.LogWriter] - [kz.gov.pki.api.layer.NCALayerServices]: FrameworkEvent ERROR:
org.apache.felix.log.LogException: org.osgi.framework.BundleException: Activator start error in bundle kz.gov.pki.api.layer.NCALayerServices [5].
Caused by: org.apache.felix.log.LogException: java.lang.NoClassDefFoundError: javafx/application/Platform
2019-05-13 14:28:31 INFO [kz.gov.pki.api.layer.service.LogWriter] - [kz.gov.pki.api.layer.NCALayerServices]: BundleEvent STOPPED
2019-05-13 14:28:31 ERROR [kz.gov.pki.osgi.layer.core.NCALayer] - Failed.
at org.apache.felix.framework.BundleImpl.start(BundleImpl.java:998)
at org.apache.felix.framework.BundleImpl.start(BundleImpl.java:984)
at kz.gov.pki.osgi.layer.core.NCALayer.main(NCALayer.kt:224)
Caused by: java.lang.IllegalStateException: Invalid BundleContext.
at org.apache.felix.framework.BundleContextImpl.checkValidity(BundleContextImpl.java:511)
at org.apache.felix.framework.BundleContextImpl.createFilter(BundleContextImpl.java:127)
at kz.gov.pki.api.layer.service.BundleLog.discoverLogService(BundleLog.java:15)
at kz.gov.pki.api.layer.fx.NCALayerServicesActivator.start(NCALayerServicesActivator.java:45)
2019-05-13 14:37:53 INFO [kz.gov.pki.osgi.layer.core.NCALayer] - NCALayer 1.2
2019-05-13 14:37:53 DEBUG [uk.org.lidalia.sysoutslf4j.context.SysOutOverSLF4JInitialiser] - Your logging framework class ch.qos.logback.classic.Logger should not need access to the standard println methods on the console, so you should not need to register a logging system package.
2019-05-13 14:37:53 INFO [uk.org.lidalia.sysoutslf4j.context.SysOutOverSLF4J] - Replaced standard System.out and System.err PrintStreams with SLF4JPrintStreams
2019-05-13 14:37:53 INFO [uk.org.lidalia.sysoutslf4j.context.SysOutOverSLF4J] - Redirected System.out and System.err to SLF4J for this context
2019-05-13 14:37:53 INFO [kz.gov.pki.osgi.layer.core.NCALayer] - Linux
2019-05-13 14:37:53 INFO [kz.gov.pki.osgi.layer.core.NCALayer] - 4.18.0-18-generic
2019-05-13 14:37:53 INFO [kz.gov.pki.osgi.layer.core.NCALayer] - /usr/lib/jvm/java-8-openjdk-amd64/jre
2019-05-13 14:37:53 INFO [kz.gov.pki.osgi.layer.core.NCALayer] - 1.8.0_191
2019-05-13 14:37:53 INFO [kz.gov.pki.osgi.layer.core.NCALayer] - /home/nickidev/.config/NCALayer
2019-05-13 14:37:53 INFO [kz.gov.pki.osgi.layer.core.NCALayer] - /home/nickidev/nca/ncalayer.sh
2019-05-13 14:37:53 INFO [kz.gov.pki.osgi.layer.core.VerifierKt] - Certificate: [278463781514179169959691607844149928005467174640] [EMAILADDRESS=AIRAT.KHAIRULIN@NITEC.KZ, GIVENNAME=МИНВАЛИЕВИЧ, OU=BIN000740000728, O="АКЦИОНЕРНОЕ ОБЩЕСТВО \"НАЦИОНАЛЬНЫЕ ИНФОРМАЦИОННЫЕ ТЕХНОЛОГИИ\"", ST=АСТАНА, L=АСТАНА, C=KZ, SERIALNUMBER=IIN761231300313, SURNAME=ХАЙРУЛИН, CN=ХАЙРУЛИН АЙРАТ] [Mon Jan 24 20:20:49 ALMT 2022]
2019-05-13 14:37:53 INFO [kz.gov.pki.osgi.layer.core.NCALayer] - System packages: javafx.beans.property,javafx.beans.value,javafx.scene.control.cell,javafx.scene.image,javafx.event,javafx.util,kz.gov.pki.osgi.layer.api,org.json,kotlin,kotlin.jvm.internal,kotlin.collections,org.osgi.service.log,org.slf4j,org.slf4j.impl,javax.smartcardio,javafx.application,javafx.collections,javafx.fxml,javafx.geometry,javafx.scene,javafx.scene.control,javafx.scene.layout,javafx.scene.paint,javafx.scene.text,javafx.scene.web,javafx.stage,javafx.util,javax.xml.parsers,org.w3c.dom,org.xml.sax,javax.net.ssl,javax.swing,javax.xml.namespace,javax.xml.stream,javax.xml.stream.events,javax.crypto,sun.security.jca,javax.crypto.spec,javax.servlet,sun.security.smartcardio
2019-05-13 14:37:54 INFO [kz.gov.pki.osgi.layer.core.NCALayer] - Scanning bundles directory...
2019-05-13 14:37:54 INFO [kz.gov.pki.osgi.layer.core.NCALayer] - (org.apache.felix.framework 5.6.10) is 8
2019-05-13 14:37:54 INFO [kz.gov.pki.osgi.layer.core.CertCondition] - Condition for kz.gov.pki.knca.applet.knca_applet is true
2019-05-13 14:37:54 INFO [kz.gov.pki.osgi.layer.core.CertCondition] - Condition for kz.gov.pki.kalkan.xmldsig is true
2019-05-13 14:37:55 INFO [kz.gov.pki.osgi.layer.core.CertCondition] - Condition for kz.gov.pki.kalkan.knca_provider_jce_kalkan is true
2019-05-13 14:37:55 INFO [kz.gov.pki.osgi.layer.core.CertCondition] - Condition for kz.gov.pki.provider.knca_provider_util is true
2019-05-13 14:37:55 INFO [kz.gov.pki.osgi.layer.core.CertCondition] - Condition for kz.gov.pki.osgi.layer.websocket is true
2019-05-13 14:37:56 INFO [kz.gov.pki.osgi.layer.core.CertCondition] - Condition for kz.gov.pki.api.layer.NCALayerServices is true
2019-05-13 14:37:56 INFO [kz.gov.pki.api.layer.service.LogWriter] - [kz.gov.pki.api.layer.NCALayerServices]: BundleEvent RESOLVED
2019-05-13 14:37:56 INFO [kz.gov.pki.api.layer.service.LogWriter] - [kz.gov.pki.provider.knca_provider_util]: BundleEvent STARTED
2019-05-13 14:37:56 INFO [kz.gov.pki.api.layer.service.LogWriter] - [kz.gov.pki.kalkan.xmldsig]: BundleEvent STARTED
2019-05-13 14:37:56 INFO [kz.gov.pki.api.layer.service.LogWriter] - [kz.gov.pki.osgi.layer.websocket]: BundleEvent STARTED
2019-05-13 14:37:56 INFO [kz.gov.pki.api.layer.service.LogWriter] - [kz.gov.pki.osgi.layer.websocket]: Found LogService on load
2019-05-13 14:37:56 INFO [kz.gov.pki.api.layer.service.LogWriter] - [kz.gov.pki.osgi.layer.websocket]: BundleEvent RESOLVED
2019-05-13 14:37:56 INFO [kz.gov.pki.api.layer.service.LogWriter] - [kz.gov.pki.knca.applet.knca_applet]: BundleEvent STARTED
2019-05-13 14:37:56 INFO [kz.gov.pki.api.layer.service.LogWriter] - [kz.gov.pki.knca.applet.knca_applet]: ServiceEvent REGISTERED
2019-05-13 14:37:56 INFO [kz.gov.pki.api.layer.service.LogWriter] - [kz.gov.pki.knca.applet.knca_applet]: Found LogService on load
2019-05-13 14:37:56 INFO [kz.gov.pki.api.layer.service.LogWriter] - [kz.gov.pki.knca.applet.knca_applet]: BundleEvent RESOLVED
2019-05-13 14:37:56 INFO [kz.gov.pki.api.layer.service.LogWriter] - [kz.gov.pki.kalkan.xmldsig]: BundleEvent RESOLVED
2019-05-13 14:37:56 INFO [kz.gov.pki.api.layer.service.LogWriter] - [kz.gov.pki.provider.knca_provider_util]: BundleEvent RESOLVED
2019-05-13 14:37:56 INFO [kz.gov.pki.api.layer.service.LogWriter] - [kz.gov.pki.kalkan.knca_provider_jce_kalkan]: BundleEvent RESOLVED
2019-05-13 14:37:56 INFO [kz.gov.pki.api.layer.service.LogWriter] - [org.apache.felix.framework]: ServiceEvent REGISTERED
2019-05-13 14:37:56 INFO [kz.gov.pki.api.layer.service.LogWriter] - [kz.gov.pki.api.layer.NCALayerServices]: Found LogService on load
2019-05-13 14:37:56 ERROR [kz.gov.pki.osgi.layer.core.FelixLogger] - [kz.gov.pki.api.layer.NCALayerServices]: Error starting file:/home/nickidev/.config/NCALayer/bundles/NCALayerServices-0.4.jar:
2019-05-13 14:37:56 INFO [kz.gov.pki.osgi.layer.core.NCALayer] - (kz.gov.pki.knca.applet.knca_applet 0.3.7) is 32
2019-05-13 14:37:56 INFO [kz.gov.pki.osgi.layer.core.NCALayer] - (kz.gov.pki.osgi.layer.websocket 0.3.2) is 32
2019-05-13 14:37:56 INFO [kz.gov.pki.osgi.layer.core.NCALayer] - (kz.gov.pki.kalkan.xmldsig 0.3.0) is 32
2019-05-13 14:37:56 INFO [kz.gov.pki.osgi.layer.core.NCALayer] - (kz.gov.pki.provider.knca_provider_util 0.7.3) is 32
2019-05-13 14:37:56 INFO [kz.gov.pki.osgi.layer.core.NCALayer] - (kz.gov.pki.api.layer.NCALayerServices 0.4.0) is 4
2019-05-13 14:37:56 INFO [kz.gov.pki.api.layer.service.LogWriter] - [org.apache.felix.framework]: FrameworkEvent STARTED
2019-05-13 14:37:56 INFO [kz.gov.pki.api.layer.service.LogWriter] - [org.apache.felix.framework]: BundleEvent STARTED
2019-05-13 14:37:56 ERROR [kz.gov.pki.api.layer.service.LogWriter] - [kz.gov.pki.api.layer.NCALayerServices]: FrameworkEvent ERROR:
2019-05-13 14:37:56 INFO [kz.gov.pki.api.layer.service.LogWriter] - [kz.gov.pki.api.layer.NCALayerServices]: BundleEvent STOPPED
2019-05-13 14:37:56 ERROR [kz.gov.pki.osgi.layer.core.NCALayer] - Failed.
